Dryer Won't Turn On
First the symptoms. Dryer was operating and tumbling. I opened it to see if the clothes were dry, they weren’t. Tried to start up the dryer again to finish drying, but when I pushed the button nothing happened. No hum no nothing.
I gave up on it and went to the laundromat. I tried it again a week later. It turned on and started tumbling! YAY! When I went to see if the clothes were dry, they were not dry. the dryer wouldn’t come on again and hasn’t since.
We checked the breaker, made sure we have power, bought the 279816 Thermal Cutoff Kit and installed it with the help of this forum (thank you so much) Still nothing.
Any ideas on what could be wrong?
P.S. Heating element replaced a year ago.
Replacement parts for WHIRLPOOL LER4634PQ0 29" Electric Dryer | AppliancePartsPros.com
Here is the wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%208528187.pdf
Is the interior light coming on when the door is opened.
If not you may have a loose connection in the wall receptacle, the unit’s terminal strip or the line cord itself.
Try turning the timer to different positions could be the timer contacts are not making reliably.
If still nothing the easiest/safest way to find the cause is to use a meter and check the components while the unit is unplugged.
Unplug it and set it to mid cycle timed dry and then check the cmponents for continuity.
The start circuit is fairly simple.
NEUTRAL , DOOR SWITCH , PUSH TO START SWITCH , %m centrifugal switch , MAIN and START motor windings , THERMAL FUSE , BU/BK timer contacts , L1
