Dryer won't stop spinning
I have Kenmore dryer model number 796.80272900. The drum doesn’t stop spinning. If you open the door, the drum stops. But, while the door is open, if you press in the door switch, the light will go out, but the drum starts spinning again. And this will all happen with the unit turned off.
Any thoughts?
Thanks in advance.
See thread: http://forum.appliancepartspros.com/dryer-repair/553058-dryer-drum-spins-while-not.html
