My dryer will not start. When you push to start, it clicks and the sensor light comes on. The status lights runs all the way through the cycle to the wrinkle shield light and the timer runs down as if it is going thru the cycle but it’s not running. What would be the likely problem?
Can you hear the motor turning or making any noise?
Check for a broken belt or open thermal fuse. Here is a copy of your tech sheet for troubleshooting.
Eric
GEW9200.pdf (326.1 KB)
