Dryer wont start
I have a maytag dryer that wont start, like no power. does anyone know what it could be?I’m thinking that it’s the switch by the door. not sure
Could also be the thermal fuse but cannot be of much help hear without a Model Number.
Often it is a white device attached to the blower housing
my model number is HYE3657AYW maytag
Here are your parts, note the wiring diagrams are at the bottom
Replacement parts for MAYTAG HYE3657AYW | AppliancePartsPros.com
Could be the door switch
The thermal fuse as mentioned earlier. This is probably the most common cause.
Also the start switch
Or the motor itself.
Try flipping your breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
With a unit that appears totally dead it is bets to check that you are getting the correct voltages at the plug first using a meter.
[QUOTE=denman;86910]Could also be the thermal fuse but cannot be of much help hear without a Model Number.
Often it is a white device attached to the blower housing[/QUOTE]
mod. pyet344ayw
billy andrus
Please start your own thread in this forum using Post New Thread, tagging onto a thread with a different Model Number will just confuse things
Thanks in advance.
