Thank you. When I push the starter button, it buzzes, and won’t start the dryer. I was going to order and replace the section in the control panel… the three parts that are listed with your diagram, but I wanted to make sure that would be a good first step. ??? Thank you.
Hi…I have this same problem with an Admiral Capacity Plus Dryer. Have you gotten any feedback on this problem? What have the experts told you to do? Thanks, Roger:confused:
It could be the motor at fault being the motor will not run when you push the start button.
