I replaced the element but it still wont heat . Also what if i got the wires mixed e.g. black wire on top red wire on bottomwould this make it not heat.
Here are the parts
82826101
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%203980060.pdf
If you are referring to the wires on the thermal cutoff, then it makes no difference.
Your problem can be a number of things re: thermal cut-off etc.
I would also check the replacement heater, it is not unheard of for a part to be bad even though it is new.
