Dryer won’t start
Brand:whirlpool
Model Number:WED92HEFC0
Main Symptom:
When I go to start the dryer it seems to want to start for a split second then does nothing. This started about a week ago. I have been sucessful a few times but only after trying several times. I don’t get any error codes at all. I haven’t replaced anything yet because I’m not sure where to start. Plus I don’t want to continue to replace the wrong parts
You will want to start by checking to make sure that the door switch is good, check the thermal fuse for continuity, check the motor and the belt switch to ensure that all are good.
