I have a question involving the hookup of a 4 prong cord to the terminal block of a dryer that is made for a 4 prong hookup. I recently bought a used dryer (Kenmore Model # 417.83042300) and I am using the terminal block off my old dryer (Frigidaire Model # FER211AS1). Both dryers used a 4 prong cord.
On the terminal block, there is a green ground wire attached to the neutral, where both the neutral from the dryer and the neutral from the wall meet. I am wondering where that green wire should be placed, since it is connected to the neutral on the terminal block. Everything else is straight forward and I know to connect the green ground from the outlet to the chassis of the dryer. I am just curious to know where the green wire attached to the neutral of the block should be placed. I have attached a picture to help for visual.
In the picture, I have connected the wire in question to chassis ground along with the ground from the wall. I believe this is incorrect though. Also, is it okay to use butt connectors to connect wires in this case since there will be a lot of current??
These are all probably lame questions, but i’m new to a lot of this stuff. Any help is greatly appreciated.
Thanks!!!
