Dryer will spin if started by hand
I have a Hotpoint Dryer (model # nbxr333eg5ww) and if I
press the start button it will not spin but if I spin it by hand
it will spin the set cycle. What could be the problem?:confused:
Here is the closest I could find on your model number.
Replacement parts for General Electric NBXR333EG0WW Electric dryer | AppliancePartsPros.com.
If the drum turns fairly easily by hand then odds are that your motor is on itโ€™s last legs.
You may want to try turning drums on a couple othetr units just to get a feel for it.
If the drum is hard to turn the at the top of the list would be the rear support bearing or the front glides.
