Dryer will not stop running in timed dry cycle
The dryer runs without stopping in a timed cycle. The timer when activated can be heard ticking.
do I need to replace the timer or the relay or the stop guard?
could someone advise?
Does the timer advancing to the Off position?
Does the dryer stop if you open the door?
Would it restart by itself when you close the door?
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KEYS850GQ0 ELECTRIC DRYER | AppliancePartsPros.com
no, the timer does not advance - but you can hear it “ticking”
the dryer stops when you open the door
the dryer starts when you close the door AND press the start button
Still need to know whether I may need a timer, relay, or Finish guard or some combination
please and thank you
Sounds like the problem is a bad timer.
