Dryer will not start
worked fine lastnight, will not start now. replaced timer several months ago, have checked breaker and have power up to timer and start switch
Check the door switch and see if its clicking and if it has continuity.
I would go with door switch also.
replaced door switch today as well as push start button and still no go
already replaced timer not to long ago.
Does it have 220/240volts at wall plug??
Remove the rear panel and check the thermal fuse (#23 on the diagram) for continuity.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL LER3624EQ1 | AppliancePartsPros.com
