My dryer just stop running, will not start at all. I dont know if it is the motor or not. I push in the start button and get nothing.
Check the outlet. You should have 240VAC. It won’t be perfect, but should be reasonably close.
my dryer still do not start, I checked the outlet and everything seems to be ok on that end. It worked 2 days ago. what else can i check?
The components to check are: Door switch, thermostats, thermal fuse, timer, and start switch. The timer is the least common of all these items to fail. All the others can be checked for continuity.
