Maytag Dryer will not start.
I can hear the ticking/buzzing from the Cycle Knob when turned to a cycle, but will not start when pressing the Start Button.
A number of issues can prevent your dryer from starting.
- Check to see if you have 240v coming into the dryer from the outlet using a multimeter.
- Check the door switch for continuity when closed. A faulty door switch will prevent it from starting.
- Check thermal fuse for continuity. It to will prevent the dryer from starting.
Whirlpool WP3392519 Dryer Thermal Fuse - AppliancePartsPros.com
After checking these items let us know the outcome.
