Dryer will not spin
[LEFT]
[/LEFT]
[LEFT]
[/LEFT]
:frowning: :confused: My dryer is not spinning at all, however, it is getting hot inside. I looked on-line for manual and trouble-shooting but didn’t have any luck. Is this the belt or motor? If so, what should I do? and where is the belt?
Thank you,
Marianne
This model does not have a broken belt cutoff switch so it will heat and the motor will turn. The belt sounds like it is broken AP2946843
[QUOTE=gmbdinc;155894]This model does not have a broken belt cutoff switch so it will heat and the motor will turn. The belt sounds like it is broken AP2946843[/QUOTE] Go to www.applianceaid.com-dryers on how to do it. Sorry I don’t know how to insert links.
thanks so much :slight_smile:
Replacement parts for WHIRLPOOL TGDX640PQ0 29" Gas Dryer | AppliancePartsPros.com
Here is the wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%208528187.pdf
gmbdinc
To insert a link copy the url, then click on the world with a paper clip in front of it icon (insert link) and paste the url in here, then OK.
thank you very much :slight_smile:
