Dryer works fine except it will not heat. This is an electric dryer. The heating element and sensor at the element both ohmn out to be good. What else?
Make sure you get 230 volts to the dryer. If ok, check the thermal fuse and heating element for continuity. You can click on your model # above to get parts.
