Dryer will not heat, timer does not work
Recently I noticed that the dryer stopped producing heat when it was in use. I also noticed the timer switch never moves and the dryer will run all day if you let it. Not certain if the two issues are related, but need to know where to check first. Dryer tumbles and moves fine, just no heat and won’t stop until the door is opened.
Any ideas?
Here are your parts includes a wiring diagram.
Replacement parts for ADMIRAL ADE7005AYW DRYER- ELE | AppliancePartsPros.com
When the timer does not run is the unit in an auto mode?
The reason I ask is that the timer motor gets it’s power from the Normally Open contacts in the cycling thermostat so if they never open it does not advance.
Try it in timed dry, now does it advance?
If yes then the problem is in the heating circuit.
First I would check the power to the unit as the heater requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
[COLOR=“Red”]Be careful as 240 volts is lethal !!![/COLOR]
If OK.
Unplug the unit and one side of the heating coil and check it.
It should be around 10 ohms.
If OK.
Check the hi-limit and cycling thermostats.
Both should be 0 ohms.
Be sure to measure the Common and Normally Closed contacts on the cycling thermostat.
[QUOTE=dhenson;607903]Recently I noticed that the dryer stopped producing heat when it was in use. I also noticed the timer switch never moves and the dryer will run all day if you let it. Not certain if the two issues are related, but need to know where to check first. Dryer tumbles and moves fine, just no heat and won’t stop until the door is opened.
Any ideas?[/QUOTE]
I’ve the exact same problem. How did you ever solve it? I’ll try the troubleshooting steps the other guy/gal suggested but my issue is with it in timer mode.
So I’ve got proper voltage and when in timer mode it trips up the circuit breaker, it drops to like 20v and I have to reset it, put it in energy savings mode and it works. So what’s that mean, in regular mode there is a short drawing a bunch extra current or something? Do I need to start sticking my mm inside this dryer somewhere? I’m up to it. Give me directions. Let’s do this. Otherwise I guess energy savings will just save me $$ on my electric bill right? Yeah, if this means like replacing an expensive part I’m good and will wait for the next part to break. Ideas?
