Heating element died a week ago, purchased from you guys a new element. New element is installed, is working fine, and dryer is drying again. However I want to make sure there isn’t anything else wrong, it appears to still be taking a little long to dry. I have thoroughly removed all lint from the dryer, all lines, manifolds, etc.
Running on high with no clothes the outlet vent temperature runs up to 160-165, then the element turns off. Vent temp slowly drops to about 125, then the element kicks back on and again returns to 165.
With a fresh wet load the vent temperature maintains a steady 105-110, with the element cycling on/off periodically to maintain that temp.
On the heating element housing, I’ve got continuity in the thermal cut-off and high limit thermostat.
I’ve got continuity on the cycling thermostat on both sets of contacts.
So what is the correct temperature to expect on the vent side with clothes in it? I’ve heard 160 is normal, but can’t find if this is with or without a load??? Obviously I’m not getting to 160 with clothes in.
I’m thinking that since the cycling thermostat allows the vent temp to reach 160 with no clothes, it should also allow it to reach 160 with clothes. Which makes me think the high limit thermostat on the heating element housing is what is cutting heat, and could be faulty.
Thanks for your assistance in troubleshooting!!!
Regards,
Robbie
