I have an older Kenmore dryer that is using too much electricity (based on very high electric bills and experiments we did to “test” which circuits were using a lot - the dryer was through the roof). Our electric bill is at least double what it ought to be.
For complicated reasons I won’t go into, we are unable to replace our dryer and need to make this one work without using so much electricity.
In order to determine why it’s using so much electricity, I used a multi-tester to test the resistance on the heating coil and it seemed fine (no extra resistance).
Are there other parts that I can use the multi-tester on to see if they are the culprit and are creating too much resistance?
I would appreciate any suggestions on that or other ideas what to check or where to look for a reason why the dryer is drawing so much power.
Thanks,
Bob
