I have a whirl pool model LER6620PQ0. For the past two years it has not done a good job drying clothes. Today its stopped making heat. It tumbles fine and makes no noise. I was wonder what it could be, is there a fuse, and how do I test the compnents to seeif they are working properly. Thanks.
Here is the parts breakdown
Replacement parts for WHIRLPOOL LER6620PQ0 29``ELECTRIC DRYER | AppliancePartsPros.com
First check the power. The heating element requires the full 240 volts while the motor etc. will run on 120 volts.
Power Check
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
Thermal Cut-off Check
Check the thermal cut-off (fuse) ( Item 9 in Section 3) with a meter see Meter section below. Should be 0 ohms (closed)
If it is blown you have to find out what caused it to go.
Note: that sometimes they do just blow on their own but changing it without checking other things is a gamble. I beleive richappy (another regular poster on this forum) has done a study on thermostats and found a wide variation of actual trip point and what is specified.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it so the thermal fuse blows.
If the above is OK then you will also have to replace the hi-limit as it should have regulated the temperature so the fuse did not blow.
Note: That unless there is another problem in the unit the hi-limit should never have to open. It is just a safety device with the fuse being a backup safety device.
You still have to find out why it blew.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it’s contacts may not be opening (welded shut).
Meter
