This dryer is a 1986 model from Wards. I replaced my belt and disconnected the wires from the timer motor thinking I had the tech sheet. I DON’T!!
I desperately need help to replace the individual color coded wires to the proper terminals on the timer. Can anyone help? I’ve put up a clothes line outside!!!
I looked for a diagram and had no luck finding one.
Did you pull all the wires off?
How many are off?
Sometimes the timers are marked with what color or number wire goes were.
Could you post some photos of the time and what wires you have to work with?
This dryer was made by Frigidaire for Wards. Post the timer part number and I’ll see if I can find a wiring diagram for a Frigidaire model that uses the same timer. By the way, how many wires did you disconnect? I’m assuming you have already checked everywhere inside the control panel and inner side of the front and side panels for a wiring diagram, right?
The timer model # is M406-4G
I pulled all the wires from the timer…the 2, 110 volt wires,blue wire,white wire, tan with jumper and orange/white wire. I also pulled the wires off of the start switch and temperature control switch. I am absolutely sure that I do not have any wiring diagram. I can’t tell you how much I appreciate the help…this is my 95 year old moms dryer and it means a lot.
Thank You so much
deleriousone,
The number I need looks like Q622122 or 5308622122. Please check. If we don’t find a diagram, it’s going to be tough connecting the timer and everything back together.
Sorry it’s Q630114
[QUOTE=ApplianceJunk;602]I looked for a diagram and had no luck finding one.
How many are off?
Could you post some photos of the time and what wires you have to work with?[/QUOTE]
I can’t send the pictures…they seem to be too large, is there any other address I can send them to?
You could email them to me and I will resize them and post them.
This timer fits some of Frigidaire’s DG650 series, like DG650EXW1 for example. The only thing I could find for it was an owner’s manual. No wiring diagram.
Hopefully the pictures will help.
Check out this place. I never used it myself, but looks good and its free. It lets you resize your photos to make them smaller.
Do the wires have any letters on them?
[QUOTE=ApplianceJunk;733]Here are the photos, sorry I did not get them posted soon.
If you still need help with it after others look at the photos I will take a closer look myself tonight. Little short on time this afternoon.
image 3[/QUOTE]
Thank you very much for posting the photos! I have had no replys yet…I did speak to the frigidaire people and they tell me that the UAN series are WASHING MACHINES…I double checked and there is no question that my dryer is UAN8324-80B…any further info would help a lot! In any case your help is greatly appreciated. It’s good that the weather in Detroit has been hot and sunny as I’m drying clothes outside.
Not sure if we have one around, but I will see if I can find one in the junk pile to take a look at.
Would have been nice if you took photos of it before you pulled the wires off. ![]()
[QUOTE=ApplianceJunk;865]Not sure if we have one around, but I will see if I can find one in the junk pile to take a look at.
Would have been nice if you took photos of it before you pulled the wires off. :)[/QUOTE]
Now why didn’t I think of that!!!
I REALLY appreciate the help so far but I’m still stuck.
Just to review for any new lookers.
A..I’m an idiot
B..It’s a Wards (Frigidaire?) gas dryer from 1986, Model # UAN (SERIES)8324-80B, Timer control # Q630114
C..I removed all the wires from the timer motor, start button and temperature control thinking I had a wiring diagram from years ago when I fixed the dryer. I didn’t look first…hence I’m an idiot!
D..The pictures are posted a few comments back, I’d add them here but I can’t figure it out.
E..There are no letters or indication as to how they match up to the controls.
F..The wires are color coded as shown in the picture a few comments back.
G..I am a radio personality in Detroit whom they allow to run multi million dollar equipment and talk on the air, however I AM AN IDIOT.
H..Whether on not I am able to find the answer to my problem…not the idiot problem,the dryer problem…I WILL work in this site on the air as very helpful if you’re, like me, an idiot.
I..HELP
John
There is one less spade on the replacement timer for this unit. What does this mean? Could it mean the wire that has no terminal second connector is to be omitted from the wiring harness on the replacement timer?
thanks!!!
The wiring is still attached. I noted the difference when comparing old and the new before installation. The new timer does not have a spade for one end of a wire that is on the old timer. There is a “bridge” between the locations on the new that is not on the old. I am wondering if this is the manufactor’s way of eleminating this short 3" wire. Thanks
I am in the process of replacing a bad timer and I also have wiring issues.
Look on the back of the timer. There should be either one or two letters next to each terminal on the timer. The same letters should appear on the individual wires, Assuming this is the original timer.
