Brand:
Model Number:Subject: GE GTD48EASW0WB – Three Replacement Timers, Dryer Won’t Shut Off, Timer Eventually Fails
I need technical assistance diagnosing a recurring dryer timer problem.
Dryer Model: GE GTD48EASW0WB
Timer Part Number: WE04X24550
I’ve gone through three replacement timers, and each one has exhibited different problems.
The most recent timer had only one noticeable mechanical detent (notch), located around the six o’clock position. Rotating the knob through the remaining settings produced no noticeable detents.
I decided to operate the dryer to see whether the timer mechanism would begin functioning normally.
I set the timer to 60 minutes. The dryer started, heated normally, and the timer advanced through 40 minutes and then 20 minutes as expected.
However, when the timer reached the OFF position, the dryer continued running. The timer kept advancing past OFF instead of stopping.
The only way to stop the dryer was to open the door. After closing the door and pressing START, the dryer would begin operating again.
Eventually, the timer itself stopped functioning altogether.
My concerns are:
- Why would the timer advance normally but fail to shut the dryer off at the OFF position?
- Could a defective internal cam, detent mechanism, or electrical contact assembly explain this behavior?
- Could another electrical component or wiring issue within the dryer be contributing to repeated timer failures?
- Is there a specific diagnostic procedure to determine whether the problem is the timer itself or another component?
- What should be checked before installing another replacement timer to prevent the same failure?
I’ve already contacted customer service regarding a replacement, but I would appreciate an actual technical diagnosis rather than continuing to replace timers without identifying the underlying cause.
Any assistance from someone experienced with GE dryer timer circuits would be greatly appreciated.
Main Symptom:
