The dryer temps are hotter than what the tech sheet shows. When I test temp at rear of dryer at highest temp setting it’s over 185 degrees . I’ve tested the high
Limit switch which test ok the no heat setting works . The thermistor on and off
Cycle seems to work temps are just too hot!
Replacement parts for KENMORE 11060882990 | AppliancePartsPros.com
Check the thermistor resistance.
Not sure what you mean by “The thermistor on and off”.
There is no on/off with a thermistor it just varies resistance with temperature.
60882990.pdf (232.4 KB)
