Dryer stopped running
I posted a question last weekend about my whirlpool dryer and did not receive an answer. I cannot find the posting and do not ahve the mdel# with me, but please try to help me.
The dryer started shutting off before the clothes were dry and there was time left on the timed dry setting. Although it would run on air fluff it would not run on any heat settings until it cooled down. I used AccuDry and it worked fine for a while but it stopped running the last time I used it when I opened the door to check on a load. Now it will not even run on air fluff.
How do we find out what part or parts need to be replaced? If you think it is the thermostat, which one? YOu have my permission to email your answer directly to me at 2robinedgar@gmail.com
Many thanks!
Robin
A Model Number may help others help you.
Off the top of my head I would say you have a blown thermal fuse.
Could be that the motor was overheating in the past and this is why it would run a cycle and then you would have to let it cool down before running it again (the motor’s internal thermal cut off was opening)
If the motor was running slow then you have less air flow and possibly it blew the fuse. Normally this is on the blower assembly.
Best way to check is unplug the unit, remove one wire from the fuse and check it with a meter, should be 0 ohms.
Jiggery pokery method is:
Unplug the unit
Short the two wires to the fuse together.
Tape them up so they cannot short to anything else.
Plug the unit in and give it a try.
If blown replace it ASAP as it is a critical safety device.
Be sure to clean/check your blower wheel and your vent system.
Check the drum rotation. Manually rotate the drum in the correct direction, it should rotate fairly easily. You may want to do this on a couple other dryers so you get a feel for it. If it is hard to rotate you will have to open it up and find out why.
Here is a good site with basic dryer repair help
http://www.applianceaid.com/dryers.html
thanks. I will get the model # tomorrow.
The model# for my Whirlpool dryer that stopped running is LEQ7030KQ1.
Replacement parts for WHIRLPOOL LEQ7030KQ1 | AppliancePartsPros.com
Here is the wiring diagram
https://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%203406661.pdf
I got your message but I am confused. The link goes to cabinet parts but I did not find the thermal fuse listed. I di find the belt, which I would like to replace as well. I also could not poen the wiring diagram document.
Thanks somuch for sticking with me!
[quote=denman;95235]Here are your parts
https://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%203406661.pdf[/quote]
[COLOR=Blue]I got your message but I am confused. The link goes to cabinet parts but I did not find the thermal fuse listed.[/COLOR]
Fuse is Item 7 in Section 3.
Just click on the section and it will open.
[COLOR=Blue] I also could not poen the wiring diagram document.[/COLOR]
I tried it and had no problem perhaps give it another try.
May take a while to download.
[COLOR=Blue]Thanks somuch for sticking with me![/COLOR]
Not a problem
My husband bypassed the thermal fuse as you suggested to test it. The dryer still did not turn on so he says it must be something else. What should we do now?
[quote=denman;95291][COLOR=blue]I got your message but I am confused. The link goes to cabinet parts but I did not find the thermal fuse listed.[/COLOR]
[COLOR=blue]I also could not poen the wiring diagram document.[/COLOR]
[COLOR=blue]Thanks somuch for sticking with me![/COLOR]
Not a problem[/quote]
First you have to check that you have the correct power.
L1 to L2 = 240 volts
L1 to Neutral and L2 to Neutral both = 120 volts
Next set the unit to timed dry and unplug it
You will need a meter to check the various components to see if they are closed.
The circuit path for starting the motor is
NEUTRAL , DOOR SWITCH , TIMER SWITCH 4 T/W, DRIVE MOTOR Start and Main windings , THERMAL FUSE , PUSH TO START RELAY contacts switch must be pushed , TIMER SWITCH 2 BU/BK , L1
It will not be a thermostat since none of them come into play until after the motor has started.
It does sound like you may have 2 problems a starting and a heating problem.
I am off to the lake for a couple days so hopefully someone else will jump in if you require additional help.
I posted a question iin Feb about my whirlpool dryer which started shutting off before the clothes were dry and there was time left on the timed dry setting. Although it would run on air fluff it would not run on any heat settings until it cooled down. I used AccuDry and it worked fine for a while but it stopped running the last time I used it when I opened the door to check on a load. Now it will not even run on air fluff.
We determined it was the thermal fuse, but which one should Iorder for model LEQ7030KQ1? You mentioned there is another problem because the dryer will not even start. What partwould that be to order?
Please email me directly at 2robinedgar@gmail.com
Many thanks
Robin
Take a look at the parts breakdown in my earlier post.
Section 1 Item 7 is the thermal fuse for the motor
Section 1 Item 9 is the fuse for the heating element
Hi there, I called as per your instructions to order the thermal fuse (#7) for the motor and the fuse for the heating element (#9) but was told that #9 is a thermal cut-off and a high limit thermostat and there is no part # for a fuse for the heating element. Since you told me the problem was not with the thermostat, I did not order. Can you possibly tell me the part # for the fuse for the ehationg element?
Robin
