Dryer starts when door is closed, w/o pushing start button
Our GE dryer works fine except, while during any cycle you open the door, then close it, the dryer will restart WITHOUT needing to push the start button as normal.
I am wondering if I need to replace the: Timer? Start button? Door switch? Other???
Please help.
Thanks!
Replacement parts for General Electric DRSR483GD1WW Gas dryer | AppliancePartsPros.com
Here is a site with an example wiring diagram (Item 28 and then Item 3)
http://www.applianceaid.com/ge-dryers.html
As usual I cannot gfind a wiring diagram for this specific model.
GE likes to keep tech info a secret, It may be in the control console.
If the unit does this whenever the timer is in a dry cycle then I would say the start switch would be at the op of the list.
Remove the switch and check it with a meter, if it is always 0 ohms then it needs replacing.
