I have an Admiral 5 cycle 3 temp dryer model # AED4475TQ1 that is 1 and a half years old. As of this morning, The dryer will only start in the cool down cycles of the 1). Auto Sense Dry high heat and 2).Time dry low heat.
And I have to slightly toggle the selector knob back and forth clockwise and counter clockwise with the start button pressed at the same time in order to get the dryer to run.
The continuity to the heating element, the thermo fuse, the high limit and cut off fuse, and cycling thermostats is good, and the cycling thermostat properly cycles on and off.
What’s wrong with the dryer? Is it the selector knob mechanism itself that is bad? ![]()
