Tried unplugging it and that didn’t work
Hi.
Does it gets warm or no heat at all?
Simon.
No it doesn’t get hot at all
I had my model number wrong. My dryer is not gas the correct number is
11087731700
Hi.
If you have the multimeter proceed with troubleshooting.
First check if there is 240VAC to the dryer (if not check the circuit breaker and outlet).
Unplug the dryer, remove the toe panel (two screws at the bottom), locate the manual - you may need it.
To check continuity remove one wire off every part you are testing.
Check continuity of the heating element (7.8-11.8 ohm), thermal cut off, hi limit thermostat.
If all of them checks OK - use the manual and run the diagnostic test.
The heater AP6013115
The cut off kit AP3874047
Post the results.
Simon.
It was the heater part thanks so much for all the help! Just ordered it and it should be here in 2 days unlike damn Sears that charges more and takes forever to get here unless you give them your first born!!!
You are welcome.
Simon.
