Dryer runs no heat
does anyone know where i can get a service manual i took the back off an don’t see anything like what the pics is showing me when i put in the model # an type of dryer thanks for any help
[ATTACH]786[/ATTACH]You access the dryer by using a butter knife to compress those clips holding down the top. The heater is located in the back and is the same as a PYE model.
maytag dryer heater and fuse.jpg (3.8 KB)
To Pop that Top begin here:
[ATTACH]787[/ATTACH]
Not that beer can top now
That will be AFTER you fix the dryer:D
top removal.jpg (2.3 KB)
A typical element for a Crosley dryer:
[ATTACH]788[/ATTACH]It also comes with a high limit and it is recommended you replace it. It mounts above the heater and needs to
come off to get to the heater.
admiral dryer element.jpg (4.2 KB)
How do I get to the igniter for a Crosley gas dryer ?
