dryer runs and spins but no heat. any thoughts?
First I would check the thermo fuse for contunuity part # AP4048636 .
if ok check power supply to ignitor unplug the quick connector on the ignitor and you should get 120V. If you don’t get 120V your flame sensor needs to be replace.
If your ignitor glows but comes on and then shuts off after a few minutes and never turns the flame back on again Replace your Ignitor and coils.
