Dryer makes a loud rubbing and scraping noise when the drum rotates clockwise. Seems to turn freely when it changes to counterclockwise rotation with little to no noise. Is this a bearing problem?
Take off the front panel and check upper dryer drum front seal.
Most likely it is damaged.
Part number for the seal AP2150497.http://www.appliancepartspros.com/partpic/Z3BqLjBfZ2xfOTMxNzM5MzAzNS9JQ1cvc290b2hwdHJhcC8%3D.jpg
Also another thing to consider is rear bearing kit.
Part number for the seal FRIGIDAIRE Rear Drum Bearing Kit, part number: AP2142648
