Dryer repair
I have a Frigidaire dryer and the tub has moved backwards and allowing the clothing to get hung between the tub and the front Is there an adjustment or part replacement to repair?
There is no adjustment, something is out of whack. You need to open it up by inserting a screw driver in the gap between the front and top near the edges to release clips that hold the top on. Flip it back and you can get to the machine and hopefully see the problem.
