Dryer Repair
Ge Dryer is noise. I already ordered the drum slides, belt and drum bearing kit. Any chance I can get step by step instructions on how to open and remove the drum? Thank you.
Here is some steps for the dryer for you..
http://www.applianceaid.com/ge-dryers.html
Open the door and remove the screws from inside of the door frame holding the top panel.
Lift the top panel and remove the screw on each side holding the front panel. Remove the wires from the door switch (mark them first) and remove the front panel.
Remove the access panel on the back of the dryer.
Remove the belt from the idler and the motor pulleys (draw a picture of the belt assembly first to know how to put it back).
Grab the drum with both hands and pull it forward.
