[FONT=Arial","sans-serif][COLOR=#000000]I have an electric GE dryer, model DRSR495EG8WW…Yesterday I pushed the start button, but only heard a low humming sound…the dryer did not start…drum will move manually. I had not used the dryer for approx. 24 hours prior. I always clean lint screen after every use. I unplugged, disconnected the duct from the dryer and vacuumed. Reconnected duct and plugged back, still only heard a low humming sound when I pushed the start button. Today I was going to attempt to hold in the door switch, push the start button, and manually turn the drum, BUT before I attempted I plugged it in and pushed the start button and it started working. Is the motor going bad? Or did it just have too much dust or lint accumulation?[/COLOR][/FONT]
The motor is the first failure suspect in such situation. If it will happen again, replace the motor.
- The motor WE17M37
Here are the breakdown diagrams and Replacement parts for General Electric DRSR495EG8WW ELECTRIC DRYER | AppliancePartsPros.com
