Dryer Problem - need schematic or wiring diagram
Brand: kenmore
Model Number: 110.69822801
Main Symptom: no heat
Parts or tests already tried: new element and motor, tested all parts on element, thermal fuse, cycling thermostat, timer, all ductwork clear.
Dryer runs about 90 seconds, beeps 3 times and shutsdown, won’t restart for about 10 minutes, element doesn’t come on in the 90 seconds run time. Put on new wheels and shaft for wheels in great shape. Will run indefinetly when belt is disconnected. A schematic would be helpful. the one I had is lost. Each leg of element tests 120v to ground but both element terminals test 0.0 when running. I’m stumped. Help please!
Here is the tech sheet!
techsheet-w10231543-revb.pdf (1.8 MB)
Oh my gosh. Thank you so so much!
