Dryer plug does not fit outlet
I just moved into a new apartment and my dryer plug (a 120/240V) does not fit into the wall (a 125/250V). They are both 3 outlet it just the bottom plug is straight with my dryer and bent in the wall outlet. I do not want to buy a new dryer, Please Help.
Amanda
[quote=Amanda626;119128]I just moved into a new apartment and my dryer plug (a 120/240V) does not fit into the wall (a 125/250V). They are both 3 outlet it just the bottom plug is straight with my dryer and bent in the wall outlet. I do not want to buy a new dryer, Please Help.
Amanda[/quote]
Sounds like you’ve got a range cord on your dryer. You’ll just need to order a dryer cord and install it the same way the current one is installed and you’ll be good to go. Below is our pt# and a picture.
AP4979356
