Brand:GE Model Number:GFDN240EL1WW Main Symptom: Thumping What happens & when: Dryer makes a once-per-rotation thump. Does not happen all the time. It does happen with light, medium, and heavy loads. No loose objects in the drum.
No worries! Have you checked the drum glides or felt seal around the drum to make sure they aren’t worn out? Also, inspect the dryer drum support shaft for wear or damage. Any of these parts can cause the symptoms you’re experiencing if they’ve worn out.
