drum out of round; wash rag got stuck between drum and front; motor stoped, drum won’t turn; is there a fuse or braker ![]()
Cannot really say what your problem is, but I suggest you take off the drum, check the thermal devices and the belt switch. It may be the drum is so damaged that the machine will not work with it.
Here is a sevice manual.
http://www.servicematters.com/maytag_library/docs/16025911.pdf
