Dryer not working after fuses changed
My dryer was running but not heating up so we automatically thought it was the heating element and replaced it only to find it not being the problem, so we researched a bit and saw that ti might be the fuses as to no heat, so we replaced the the thermal fuse and the cycling thermostat and put the old heating element back in and now the dryer doesn’t even start, so we put the new heating element back in so all could be new and still nothing. PLEASE HELP.
You have to start by checking the power.
If you have no experience then you may want to get a pro in.
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
[COLOR=“Red”]Be careful as 240 volts is lethal !!![/COLOR]
  4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
