Dryer not starting
Just stopped working. I’ve looked thru the forums and did what I saw on the others, However its still not working. I’ve gone thru my wiring and tested volts what I found is I’m only getting 110v to one side of the element, which is the main feed from the wall. The other side comes from the motor. I have 110v at the motor but not coming out. My wife wants to buy new dryer but I would like to fix it. Its not that old. Any help would be greatly appreiciated.
[QUOTE=saylols;301939]Just stopped working. I’ve looked thru the forums and did what I saw on the others, However its still not working. I’ve gone thru my wiring and tested volts what I found is I’m only getting 110v to one side of the element, which is the main feed from the wall. The other side comes from the motor. I have 110v at the motor but not coming out. My wife wants to buy new dryer but I would like to fix it. Its not that old. Any help would be greatly appreiciated.[/QUOTE]
There is a thermal fuse mounted on the blower housing. That will be your problem. Tom ApplianceEducator.com
Tom,
I did a continuity check on every little 2 wire thing mounted on blower and heater housing, all test good. Am I not testing them right. I’ll add this to the mix- My wife was able to get it started the other day by messing with the timer switch, however now nothing helps. Thanks
[QUOTE=saylols;302054]Tom,
I did a continuity check on every little 2 wire thing mounted on blower and heater housing, all test good. Am I not testing them right. I’ll add this to the mix- My wife was able to get it started the other day by messing with the timer switch, however now nothing helps. Thanks[/QUOTE]
As long as you pulled one wire off of each thing you checked, you then got good readings. If it is all well, I would go with the timer, because of your wife messing with it to get it to run. I have seen that plenty of times with my customers. Tom ApplianceEducator.com
