Dryer Not Puching Out Hot Air
Hello there I was wondering if there is any way you could help me I was using my dryer one day and everything was working fine. Then today when I went to go transfer my clothes from washer to dryer I relized I had to keep adding more time on my dryer cause the thing is not pushing out any hot air and the clothes are drying it is just taking them a very long time to dry with no hot air. I xalled a repair tech and they was gonna charge me like 60 dollars just to come and look at it then pay for parts and labor. So any suggestions on what the problem could be. I don’t have the manul to the dryer either and I also relized that the lint filter button keeps going off and the thing gets changed every time I put in a new load so it is not full but it is saying it is. That is not the big issue I can handle that I am more worried why it is not pushing out no hot heat and what it will cost to fix it roughly.
thank you
LORI
Perform the tests as described in the attached file and post the results.
Here are the breakdown diagrams and Replacement parts for BOSCH WTA3500 UC/04 | AppliancePartsPros.com
Dryers - Service tips and Test programs.pdf (566.8 KB)
