Dryer not heating
The dryer will come on and light up and go thur the cycle then goes out, it will come back on and just glow but will not ignite. How do I test the igniter sensor or the coils to see if they are working or is there something else I should be checking?
Thanks,
Jackie
you have not reply back,with answer for my dryer.
Jackie
There is no doubt the problem with your dryer are bad coils on the gas valve. Unfortunately the model number you provided is not complete and I’m not able to give you as much help as I would like.
Its a Signature 2000 from Montgomery Wards, Model# FFT-8589-80B, Serial# 91C21728, hope this help.
Jackie
Hi Jackie,
If you need further help, please post it here.
