i have problem with my dryer heating up also my timer will not turn blowing cold air and tub moves
Replacement parts for WHIRLPOOL LER5636PQ0 | AppliancePartsPros.com
Here is a wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%208528187.pdf
Try the unit in timed dry mode.
If the timer still does not advance you may have a power problem.
Note that both the heater and timer motor run off of the 240 volts.
Turn the breaker off/on slowly a couple times. Better yet check it with a meter.
If it does turn then it could be the heater is blown.
In auto modes the voltage for the timer goes through the heating coil.
Easiest way to check it is with a meter.
