Dryer not heating and it's not the heating element
I do not see any burned wires and the wire connections look clean
I have the same problem with my Whirlpool, Wires were burnt but repaired with Good splicing, Continuity still viable and all the fuses,Heating Element, connections are good and tight. If you find out, Let me Know. Maybe we have the same recourse to fix the problem.
Replacement parts for WHIRLPOOL LE8860XWQ0 Residential Dryer | AppliancePartsPros.com
First check the power to the unit.
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
The heating element requires the full 240 volts.
L1 to L2 should be 240 volts
If OK
If OK
[COLOR=“Red”]Be careful as 240 volts is lethal !!![/COLOR]
Next check the heating coil for resistance, should be around 10 ohms.
Next check the thermal cut-off (Item 6 in Section 4), it should be 0 ohms.
If blown (infinite ohms) there are other things to check before replacing it as you have to find out why it blew.
  4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
