Bought this used and doesn’t get very hot. A local repair shop said it could be the heating element and/or the thermostat.I’ve looked on youtube so I’m sure I can change out the parts myself. What should I do?
Parts for Whirlpool LER3624PQ1 Dryer - AppliancePartsPros.com
If you click on a part’s picture a new page will open often with more info about it.
See the attachment for the wiring diagram.
I would check the heating element first.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 8 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on low.
- When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
WED5300.pdf (505.7 KB)
