My Dryer Isn’t Heating Well. It Takes Two Cycles To Dry A Load Of Clothes.
[FONT=Times New Roman][SIZE=3][COLOR=#000000]Typically poor airflow will cause this on these dryers. Check the vent and if it is clogged clean it out. Make sure you are getting good airflow all the way out the vent with the dryer running. Hope this helps! Clothes Dryer Repair Guide[/COLOR][/SIZE][/FONT]
