Dryer Not cooling down
At the end of the drying cycle the clothes are extremely hot and still wrinkled. I checked the vent, dryer and hose, everything is clear. An easy fix or do I need a new dryer?
Hello Hawki39. Check and make sure the blower wheel is not clogged or bad. Also, check the heating element and make sure the coil is not grounded to the housing and causing the element to stay on.
AP6010602
AP3094254
