My dryer stopped bllowing hot air any idea what part I would have to replace to get it to blow hot hot again?
Here your parts
Replacement parts for WHIRLPOOL EL4030VW0 | AppliancePartsPros.com
Could be a number of things.
First flip your breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker. Better yet measure the plug for 240 volts.
Could be Item 6 in section 3 is blown. This is a thermal fuse. If it is blown be sure to clean the interior and your vent system.
Could be the heater is blown.
If you do not own one I would suggest you purchase a meter. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
