I have a de410 dryer (maytag). The tumbler spins and the air blows, but there is no heat.
I checked continuity across the thermostat (with wire disconnected) and the resistance is zero. Which I believe is correct and normal. So then I assume that the problem is the heater. I can only see one terminal from the back access of the dryer, so my questions are:
Is my trouble shooting correct to target the heater?
How do I access the heater to repair? Do I need to take apart the whole dryer or can this be done from the back or is there access from the front?
[COLOR=“DarkRed”]1) Is my trouble shooting correct to target the heater?[/COLOR]
Yes. There is also a hi-limit thermostat and perhaps a thermal fuse (cut-off)
I would check the power first. The heating coil requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
[COLOR=“Red”]Be careful as 240 volts is lethal !!![/COLOR]
[COLOR=“DarkRed”]2) How do I access the heater to repair? Do I need to take apart the whole dryer or can this be done from the back or is there access from the front?[/COLOR]
See the manual.
You may as well open it right up and give it a bit of an overhaul.
Check the front and rear drum supports, the idler wheel, the drum seals, the belt, any internal air flow seals etc.
Give the interior including the blower wheel a good cleaning.
Also a good time to check/clean your vent system.
