does anyone know how to remove the motor. i removed the wires and the c tension clips but the motor will not pull out.
Thank you,
paul
Model MDE9700AYW
And a service manual and tech sheet
http://www.servicematters.com/maytag_library/docs/16025911.pdf
http://www.servicematters.com/maytag_library/docs/16026116.pdf
I noticed you did not say, you took the blower wheel off. It has to come off too. Tom ApplianceEducator.com
