in replacing the dryer motor switch there are two prongs at the top with a blue wire coming off one with a clip on both ends. where does the other end go, is this a jumper to the other prong or what?
I cannot find any info on this unit.
Perhaps the following will help. This assumes that the unit is actually a Whirlpool.
http://www.applianceaid.com/whirlpool-dryers.html
Check out 13 and 14
[quote=denman;256613]I cannot find any info on this unit.
Check out 13 and 14[/quote]
thank you, the information was just what I needed, after connecting motor wires I cleaned all the dust from motor housing and armature and dryer is working like new.
