Dryer malfunction
Brand:
Model Number: WED9150WW1
Main Symptom: stopped working
I think my most likely more than 10-year-old Whirlpool dryer is broken and wondering whether and how it could be fixed, or should repurchase a new one.
I realized it not working as well as some burnt smell (rubber like but not sure) and then when it is turned off the inside drum doesnt move smoothly and is heavy. When I realized it was not moving it was warm inside so upto some point it was heated. When I press the start button there are not sounds or movement at all. It was rattling a lot for the past year or so. I am not a repair savvy person, so I wanted to ask the community before opening up my dryer because i live in an apartment and do not have a safe space to keep the dryer disassembled.
planning to purchase this.
Honestly, if you pull the main top off by removing the screws holding it on the top back of the unit, check the drive belt to make sure that it is not broken. If the belt is broken then open the unit and make sure that the rollers and idler pulley are not seized or damaged.
